AD9162 VDD12A
On the datasheet, it says it is ok to power VDD12A and DVDD from the same supply.
If running DVDD at 1.3V for 6GSPS operation, is it still ok to power these together?
Will
Parents
  • Hi Will.R,
     The VDD12A supply can be connected to the digital DVDD supply with a separate filter network. All of the SERDES 1.2 V supplies can be connected to one regulator with separate filter networks. The IOVDD supply can be connected to the VDD25_ DAC supply with a separate filter network, or can be powered from a system controller (for example, a microcontroller), 1.8 V to 3.3 V supply.
    The AD9162 require power sequencing to avoid damage to the DAC. A board design with the AD9161/AD9162 must include a power sequencer chip, such as the ADM1184, to ensure that the domains power up in the correct order. The ADM1184 monitors the level of power domains upon power-up. It sends an enable signal to the next grouping of power domains.
    When all power domains are powered up, a power-good signal is sent to the system controller to indicate all power supplies are powered up. The IOVDD, VDD12A, VDD12_CLK, and DVDD domains must be powered up first. Then, the VNEG_N1P2, VDD_1P2, PLL_CLK_VDD12, DVDD_1P2, and SYNC_VDD_3P3 can be powered up. The VDD25_DAC domain must be powered up last. There is no requirement for a power-down sequence.
    The power supply sequencing requirement must be met; therefore, a switch or other solution must be used when connected to the IOVDD supply with VDD25_DAC. For the lowest noise performance, use a separate power supply filter network for the VDD12_CLK and the VDD12A pins.
    Zaid
Reply
  • Hi Will.R,
    Zaid
Children
No Data
