I am trying to get AD9172 working.
I am not able to get it configured so that the HMC7044 PLL, AD9172 DAC and Jesd PLL lock.
Red led is lit up on AD9172 board. Please see the attached picture. Also, I do not see any of the PLLs locked on GUI.
Please let me know what could be wrong.
Mallesh
Clock output at C423 is good (122.88 MHz). I tried with external reference(J41) and on board crystal. It still does not work. HMC7044 PLL is not locking at all.
Assumed answered offline.
I am having the same issue. I am using the ADS7-V2EBZ for the interface. How did you fix your problem?
I could not get this working. I was pulled into some other project and did not go back. I will start investigating again later. Please post solution, if you are able to solve this issue.
Thank you.
