LTC2107/LTC2209 : 1.25V external reference
The user is confused about implementing a 1.25V external reference with the LTC2107 and LTC2209 ADCs. The final answer clarifies that the external reference applied to the SENSE pin sets the ADC's full-scale range but does not affect the VCM output, which remains derived from the internal reference and should be used for the common-mode bias of the analog input circuitry. The VCM output is approximately 1.2V for the LTC2107 and 1.25V for the LTC2209, and slight variations between multiple ADCs can impact performance.
Product Number: LTC2107
Hello EZ team,
I'm confused about the use of a 1.25V external reference with the LTC2107.
Per the figure 7 in the datasheet, it seems the external voltage (applied on the SENSE pin) goes only to the internal ADC circuitry, but is not routed back to the VCM output :therefore I conclude that the external voltage must also be used on the PCB for the circuits of the analog inputs in place of the ADC vcm output.
Now if I look at the schematics of the DC2183A board, the external ref is connected to the SENSE as expected, but only the ADC vcm output is connected to the analog inputs circuits, and not the external reference.
Now if I look at the LTC2209 datasheet, it's even more confusing.
Figure 6 in the datasheet of the LTC2209 is similar to the figure 7 of the datasheet of the LTC2107.
But, per the figure 7 in the datasheet of the LTC2209, it seems now that the external voltage (applied on the SENSE pin) goes to the internal ADC circuitry (2.5V), and the VCM output delivers 1.25V to the analog inputs circuits.
This is confirmed by the schématics of the DC1281A board, where the implementation is the exact same as the DC2183A.
Can you help me understand properly how to implement an external 1.25V reference with the LTC2107/2209?
Thank you,
Eric
Thread Notes
  • Hi  ,
    Moved this query to High-Speed ADCs. Someone here will be able to help you.
    Francis
  • Hi
    Thank you for your interest in the LTC2107 and LTC2209.
    The external reference applied to the SENSE pin establishes the ADC reference and full-scale behavior. It does not replace the VCM output used to set the common-mode bias of the analog input network.
    For the LTC2107, SENSE is the reference programming pin. Applying an external 1.25 V ±25 mV reference to SENSE automatically selects external-reference mode. The ADC input range remains 2.4 V p-p with PGA = 0, whether the internal reference is selected by tying SENSE to VDD or GND, or an external 1.25 V reference is used.
    The VCM output remains approximately 1.2 V and is derived from the internal 1.25 V bandgap reference. As shown in Figure 7, the external reference applied to SENSE is not routed to VCM. Therefore, VCM should still be used to provide the common-mode bias for the analog input circuitry.
    The same principle applies to the LTC2209. An external 1.25 V or 2.5 V reference can be applied to SENSE, resulting in a 2.25 V p-p input range with PGA = 0. The 1.25 V VCM output remains the intended common-mode bias for the analog input circuitry and is derived from the internal 2.5 V bandgap reference.
  • Hello JAlipio,
    forgive my ignorance, but what is the purpose of providing an external reference (for the FS) if the VCM is not also dependent on it?
    As I understand it, VCM is always built from the internal reference and must always be used for the analog circuits, not matter what choice is made for SENSE.
    Then what does this figure mean?
    Last question:
    if I use 2x instances of the ADC on the PCB, fed by the same sync'ed analog signals, what would be the impact of having sligthly different VCM1 and VCM2?
    Thanks again.
  • Hi
    The purpose of using an external reference is primarily to improve the gain accuracy and/or thermal drift characteristics of the ADC. It also allows the ADC to use a system-level reference independent of its internal reference. The LTC2107 datasheet separately characterizes gain error, full-scale drift, and transition noise when operating with an external reference.
    Regarding the figure, it shows how ADC performance, such as SFDR, varies with the common-mode voltage applied to the analog inputs. This is separate from the reference that establishes the ADC's full-scale behavior. A stable and appropriate VCM is therefore important for maintaining optimum ADC performance. The LTC2107 provides a dedicated VCM output of approximately 1.2 V for this purpose.
    For two ADCs, each device's VCM output can be slightly different. The LTC2107 specifies VCM from 1.17 V to 1.23 V, so some device-to-device variation is expected. Because this is a common-mode shift applied equally to AIN+ and AIN−, it does not directly change the differential input amplitude. However, I would not say that the effect completely cancels. A difference in common-mode operating point can result in a small difference in ADC performance between the two devices.
