AD6641-500EBZ+ HSC-ADC-EVALCZ – Request for External Hardware Trigger Support
The user inquires about external hardware triggering for the AD6641-500EBZ + HSC-ADC-EVALCZ using the ad6641_fifo.bin firmware. The final answer confirms that this firmware does not support external triggering through J7/SMA1, and the evaluation platform is not designed for continuous, trigger-based data acquisition. A custom FPGA solution is recommended to implement the required functionality, including pre-trigger buffering and automatic rearming.
Product Number: HSC-ADC-EVALCZ (FIFO501B, Virtex-4)
Hello.
We are developing a cable monitoring system called CapaDyne, based on high-speed pulse injection and analysis of reflected signals.
We currently have the following evaluation hardware:
  • ADC: AD6641-500EBZ (12-bit, 500 MSPS)
  • FPGA capture board: HSC-ADC-EVALCZ (FIFO501B, Virtex-4)
  • Sampling clock: External ADF4351 at 500 MHz
  • Software: VisualAnalog and SPIController
  • FPGA firmware: ad6641_fifo.bin
The hardware is working correctly. We can capture high-speed pulses and their reflections, and VisualAnalog successfully transfers the acquired data to the PC via USB.
We have also configured VisualAnalog for Continuous Run with automatic CSV saving, allowing us to collect hundreds of separate acquisitions without manual intervention.
What we want to achieve
Our objective is to synchronize ADC acquisition with an external pulse generator.
We would ideally like the following acquisition sequence:
  1. The ADC is armed and ready to capture.
  2. An external hardware trigger, synchronized with our pulse generator, is received by the capture system.
  3. The ADC captures a short window of approximately 3–5 µs, preferably including some pre-trigger samples.
  4. The acquired samples are transferred to the PC via USB.
  5. The system automatically rearms for the next trigger.
  6. This process repeats continuously, allowing us to collect thousands of synchronized acquisitions.
We only require one analog acquisition channel at 500 MSPS.
Our pulse generator currently operates at approximately 28 kHz, although a lower repetition rate would be acceptable if necessary.
We would prefer to retain each acquisition separately and perform signal averaging and analysis on the PC.
Our main question concerns the J7 (SMA1) external trigger input on the HSC-ADC-EVALCZ.
We understand that this capture board supports external triggering with certain ADC-specific FPGA firmware configurations.
However, we have not been able to determine whether this functionality is supported by the standard ad6641_fifo.bin firmware.
Could you please help us clarify the following?
  1. Does ad6641_fifo.bin support external hardware triggering through J7/SMA1?
  2. If supported, which FPGA register settings and trigger signal specifications are required?
  3. If it is not supported, is there an alternative AD6641-compatible FPGA firmware that enables J7 external triggering while remaining compatible with VisualAnalog?
  4. Would it be possible to obtain the FPGA source code and project files for ad6641_fifo.bin, should a firmware modification be necessary?
  5. Alternatively, can the AD6641's internal Continuous Capture Mode and differential FILL± inputs be used to implement this functionality with the existing HSC-ADC-EVALCZ hardware?
  6. Can the system automatically rearm and capture multiple externally triggered records without requiring the user to manually restart each acquisition?
We would strongly prefer a solution using our existing evaluation hardware and software.
Any documentation, suitable firmware files, or application examples would be greatly appreciated.
Thank you very much for your assistance.
CapaDyne Development
  • Hi
    Thank you for your interest in using AD6641.
    Kindly give time to the product owner  to review and respond to your query.
  • Hi
    Unfortunately, the AD6641-500EBZ + HSC-ADC-EVALCZ and VisualAnalog does not support external triggering through EVALCZ J7/SMA1. Additionally, the FPGA source code (ad6641_fifo.bin) does not include external trigger functionality, so this capability cannot be enabled through configuration changes alone.
    The AD6641 evaluation platform was designed primarily for device evaluation and characterization, not for continuous, trigger-based data acquisition applications.
    For your application, the recommended approach would be to implement a custom FPGA-based acquisition solution interfacing directly with the AD6641. This would allow implementation of external triggering, pre-trigger buffering, automatic rearming, and continuous collection of synchronized acquisition records tailored to your application requirements.
