AD9689 JESD PLL Lock Issue at 1 GSPS
Product Number: AD9689
Software Version: RTL
Hi Team,
I am bringing up the AD9689 in Full Bandwidth Mode using RTL code based on the initialization sequence described in the AD9689 datasheet (Page 81).
The hardware being used is:
  • AD9689-2600EBZ Evaluation Board
  • ADS8-V1EBZ FPGA Carrier Board
At this stage, I am only checking the JESD PLL lock status and have not connected the JESD lanes to the FPGA yet.
Clock Input
A signal generator is connected to the AD9689 CLK+/- inputs.
Configuration Used:
The initialization sequence follows the datasheet example, with the following modifications for 1 GSPS operation:
  1. Register 0x056E = 0x10
    • JESD PLL lane-rate range selection
  2. Register 0x0590 = 0x0F
    • Subclass 0 operation
All other register writes and the initialization sequence are the same as the datasheet example.
After writing 0x14 to Register 0x0571 (JESD204B Link Power-Up), I wait 5 ms before reading the PLL status register (0x056F).
Issue Observed:
When the ADC sampling clock is 1 GHz, the readback from Register 0x056F is:
0x056F = 0x00
which appears to indicate that the JESD PLL is not locked.
However, when I configure the same hardware using the ACE software, the JESD PLL reports a locked condition.
For verification , I varied the ADC sampling clock frequency and re-ran the complete RTL initialization sequence each time and the readback details for the PLL lock are as follows:
Clock Register 0x056F
1.2900 GHz 0x80
1.2840 GHz 0x80
1.2835 GHz 0x88
1.2831 GHz 0x08
1.2825 GHz 0x08
1.2820 GHz 0x08
1.0000 GHz 0x00
I exported the ACE register configuration and compared it against my RTL configuration. The key JESD-related registers appear to match, but the ACE export contains approximately 577 register writes in total.
My questions are:
  1. Is the Page 81 initialization sequence sufficient for Full Bandwidth Mode at 1 GSPS, or are additional registers required beyond the documented sequence?
  2. Is Register 0x056E = 0x10 the correct setting for a 1 GSPS configuration with:
    • L = 8
    • M = 2
    • F = 1
    • Subclass 0
  3. Does the ACE software perform additional initialization steps that are required for reliable JESD PLL lock?
  4. If the full ACE-generated register set must be applied, is there a recommended register programming sequence that should be followed?
Any guidance on  the minimum required initialization sequence for 1 GSPS operation would be appreciated.
Thank you.
