I would like to use the on-board Y1 oscillator as the ADC sample clock instead of an external clock source. However, in the schematic I noticed that R209 is marked as DNI.
Could you please confirm the following?
Can I use the on-board Y1 oscillator by populating R209 and setting the related jumper(s) appropriately?
If so, what exact rework or jumper configuration is required to enable Y1?
Does the Y1 path feed the ADC clock directly, or can it be routed through the AD9517 optional clock path?
If the AD9517 path can be used, is it possible to derive a clock rate that is more suitable for the ZedBoard reference design than the on-board 500 MHz oscillator frequency?
Is there an official or recommended clock configuration for using the AD9434-FMC-500EBZ with ZedBoard?
I have seen different schematic/document versions regarding the clock path. Could you please let me know which document or board revision I should follow for this configuration?
My main goal is to understand whether the on-board oscillator can be used reliably with ZedBoard, and if so, what the correct hardware configuration is.
