External Trigger Configuration via Python/DLL for AD9643 and HSC-ADC-EVALCZ
The user is evaluating the AD9643 with the HSC-ADC-EVALCZ board and seeks guidance on configuring the external trigger via Python and the .dll, hardware trigger specifications, and system behavior during trigger wait. The final answer confirms that a rising edge from 0V to 2.5V is required for the trigger, data transmission is not blocked while waiting, and the FPGA outputs previously captured data. The user requested the FPGA source code for reference, which can be provided after accepting a friendship request for verification.
Product Number: AD9643
Hello ADI Support Team,
We are currently evaluating the AD9643 using the HSC-ADC-EVALCZ evaluation board. Our primary goal is to capture data using a custom Python script that directly calls the provided .dll, rather than relying on the VisualAnalog GUI. We are now preparing to test the external trigger functionality within this Python-based setup.
To ensure we do not accidentally damage the evaluation boards, we are holding off on the hardware setup until we can confirm the exact specifications. Could you please advise on the following three points?
1. Software Configuration (via Python / .dll): When controlling the board programmatically via Python and the .dll, how should we configure and enable the external trigger? Are there specific DLL API functions or SPI register writes required? Additionally, do we need to load a specific custom FPGA .bin file for this external trigger operation?
2. Hardware Specifications: What are the required voltage levels (e.g., 2.5V CMOS?) and the trigger edge (rising or falling) for the hardware trigger input (SMA1 / J7)?
3. System Behavior: While waiting for the external trigger, is the data transmission from the FPGA board to the PC blocked? Or does the FPGA output empty data (e.g., zeros) or repeat the previous data from its FIFO?
Thank you in advance for your support.
