Clarification on Channel Power‑Down Behavior and Timing Specifications
The user inquires about the AD9253 channel power-down functionality. The final answer clarifies that powering down a channel disables both the ADC core and LVDS output path, with a typical power consumption of 2 mW in power-down mode. The wake-up time from power-down mode is 375 μs, and the device does not support independent power-down of the ADC core and LVDS output core. Standby mode, which keeps the internal reference circuitry powered, has a faster wake-up time of 250 ns.
Category: Datasheet/Specs
Product Number: AD9253
Hi Team,
We are using the AD9253 in our project and would like clarification regarding the channel power‑down functionality:
  • 1. When a channel is powered down, does this action disable only the ADC core or only the LVDS output core, or both together of a channel ?
  • 2. What is the expected time required to power down a channel and bring it back up again, at SPI operating frequency of 20 MHz?
  • 3. Is there a method to independently power down the ADC core and the LVDS output core of a channel instead of powering them down together?
  • Hi
    Thanks for using AD9253.
    1. When a channel is powered down, both the ADC conversion core and its associated LVDS output path are disabled together, and when a channel is disabled, it typically dissipates 2 mW.
    2. The wake-up time from power-down mode for the AD9253 is typically 375 µs. This duration is required for the device to return to normal operation. The power-down mode can be activated via the Serial Port Interface (SPI) or by asserting the PDWN pin high.
    3. The AD9253 does not provide a method to independently power down the ADC core and the LVDS output core of a channel. Both components are powered down together. However, the device offers a standby mode, which keeps the internal reference circuitry powered for faster wake-up times. In standby mode, the digital datapath clocks and outputs are disabled, and the wake-up time is significantly faster, at 250 ns, compared to the 375 µs for full power-down mode. Both power-down and standby modes can be controlled via the SPI or the PDWN pin.
    For additional details, please refer to the Power Dissipation and Power‑Down Mode section of the AD9253 datasheet.
