AD9213 TRIG_X and Source Code
Product Number: AD9213
Hi ADI Applications Team,
I am currently working with the AD9213 and would like to clarify and verify the behavior of the TRIG_x signal.
1. TRIG_x functionality
Is TRIG_x capable of controlling the ADC sampling start point or resetting the ADC data pipeline for a single device, similar to a traditional triggered ADC behavior?
Or is TRIG_x intended only for internal digital functions, such as:
  • NCO synchronization
  • DDC frequency hopping
  • Multichip synchronization in conjunction with SYSREF_x
We would like to confirm whether TRIG_x has any direct impact on the ADC sampling process itself, or if ADC sampling is entirely determined by the encode clock.
2. Register configuration for TRIG_x verification
Could you please advise on the recommended register settings and verification procedure to confirm that TRIG_x is functioning correctly for a single device?
For example, observing NCO frequency hop or phase discontinuity at the DDC output.
3. FPGA reference design support
We have purchased the following evaluation boards:
  • AD9213-10GEBZ-B
  • ADS8-V1EBZ
Is it possible to share us to the FPGA reference design code used with this platform?
We have reviewed the following resource:
https://wiki.analog.com/ad9213_ce
Any additional reference designs, example projects, or internal documentation would be greatly appreciated.
Thank you very much for your support.
  • Hi
    Thanks for using AD9213.
    Kindly give time for the product owner ( ) to look into this and provide their response.
  • Hi  ,
    Just a gentle follow-up on this thread.
    We wanted to check if there is any update from the product owner ( ) regarding the AD9213 TRIG_x behavior.
    This information would be very helpful for our ongoing evaluation and test planning.
    Please let us know if any additional details are needed from our side.
  • Hi  ,
    Following up on the AD9213 TRIG_x behavior question.
    The customer is progressing with evaluation and test planning, and this clarification would be helpful for their next steps.
    Please let us know if there is any update from the product owner ( ), or if additional information is needed from our side.
    Thank you for your support.
  • Hi  ,
    Apologies for delay response.
    To proceed with the fpga reference design code, we need the customer information register to myanalog and email us directly the registered work email address. I'll get back to you regarding your other concern. Thanks.
  • Hi  ,
    Thank you for the update.
    I will submit a Technical Support Case using my registered MyAnalog work email address (ITRI) to proceed with the FPGA reference
    design code.
    Looking forward to your follow-up on the other concern.
    Thanks again.
  • Hi  ,
    Once we have your information, we will send the reference code thru Secure Software Download, an email link for you to download the code.
    As for your other concern, Trig_x is a dedicated differential trigger input used to synchronously command digital event most notably NCO/DDC profile changes and NCO phase sync for fast frequency hopping and multi-chip alignment in. It has no direct impact on ADC sampling process and has no capability on controlling ADC sampling start point, the encode clock has direct impact in ADC sampling process not the Trig_x.
    As for the register configuration, the datasheet on p.42 provides step by step in setting up multichannel NCO features including enabling the Trig_x function. I'll get back to you once I could find a sample register writes for NCO features utilizing the trig_x function.
    Thanks.
  • Hi
    Thank you for the detailed explanation.
    We understand that TRIG_x is used to synchronously control digital events, such as NCO/DDC profile switching and NCO phase
    alignment, and that it does not control the ADC sampling start point, which is determined by the encode clock.
    We also understand that SYSREF_x is responsible for establishing and resetting NCO phase coherence.
    It would be very helpful if you could share a sample register write sequence or reference procedure for enabling and validating TRIG_x
    based NCO channel switching, particularly for a single AD9213 device.
    In addition, we would like to ask whether TRIG_x activity or its effect can be observed or confirmed via the ACE Tool, for example through:
    • Register status or flags
    • Observable NCO/DDC behavior
    • Phase continuity or frequency switching behavior
    • Any other recommended indicators (ACE or FPGA side)
    For your reference, we have already received the confirmation email from Analog Devices Technical Support, and we have replied to that email accordingly.
    We look forward to your guidance.
  • Hi  ,
    Just a gentle follow-up on our previous question regarding TRIG_x validation on AD9213.
    Could you please let us know if there is any update when you have a moment?
  • Hi  ,
    Hope you are doing well.
    Just a kind follow-up on our TRIG_x validation question for the AD9213. When you have a moment, we would greatly appreciate any
    update you may have.
  • Hi  ,
    Just checking in on our TRIG_x validation question for the AD9213.
    Any update or suggestion when convenient would be greatly appreciated.
