Clarification on Digital Interface of AD9215
Category: Datasheet/Specs
Product Number: AD9215
I will be working with the AD9215 ADC in an upcoming project. While reviewing the datasheet, I noticed that the documentation primarily mentions the D0–D9 data lines, but lacks detailed information about the digital interface protocol specifics.
I’m trying to understand how to correctly capture and process this parallel data stream using an FPGA—preferably on an AMD Zynq UltraScale+ RFSoC platform. In my past experience with other ADCs and DACs, there is typically a serial interface(like SPI) for register configuration. Since the AD9215 appears to be a non-programmable device, I’m fine with the absence of such an interface. However, my main concern is how to interpret and reliably sample the output data.
Additionally, I came across a timing diagram which shows that the device introduces a latency of six sampling clock cycles before the corresponding input sample appears at the digital output. I would appreciate any technical insights into how this latency should be handled in the FPGA logic.
If there are any reference designs or implementation examples available for interfacing the AD9215 with an FPGA, that would be extremely helpful.
Thank you in advance for your support.
Sourav
