AD9094-1000EBZ // Accessing Timestamp Value in VisualAnalog
Product Number: AD9094-1000EBZ, AD9094
Software Version: VisualAnalog 1.9.48.1 , ACE 1.30.3336.1477
I am testing four AD9094-1000EBZ systems that I want to synchronize. I would like to set the development boards into 'timestamp' mode and read out the sysref value. When I test this setup, the control bits seem to be stripped out of the data stream. Is there a way to access the control bits via VisualAnalog?
Each development board is connected to an ADS7-V2 FPGA. I am using the 'ad9694_ads7v2_split.bin' file to program each FPGA. I was advised by ADI Support to use this file, as it programs the FPGAs to listen to the external TRIGGER port.
I am using VisualAnalog Version 1.9.48.1 to program the FPGAs, and to program the AD9094-1000EBZ I am using ACE version 1.30.3336.1477 with the AD9094 plugin version 1.2024.43100.
Luke
  • Hi
    Thank you for using AD9094.
    Unfortunately, Visual Analog is not capable of accessing the control bits in the data stream. The control bits are attached to the data stream before it undergoes the 8-bit/10-bit encoding process. This typically happens within the ADC's digital processing block. See below data framing:
  • Hi JAlipio,
    Thank you for the response. I see that the control bits get added as 'tail bits' during the 'JESD204B Sample Construction' stage in the image your posted. It is unclear to me where those control bits later get stripped from the sample frame.
    Are you saying that the control bits for each JESD204B frame are only used internally in the AD9094, and can not be read outside of the device?
    My goal is to align the data streams from multiple AD9094-1000EBZ systems. I do not need this alignment to occur in real-time, my plan is to perform this alignment in post-processing.
    Reading through the 'Multichip Synchronization' section of the datasheet for AD9094, it seems to me that there are two synchronization methods.
    The first method 'Normal Mode' uses the SYSREF signal to adjust the internal timing of the AD9094, such that multiple AD9094 can operate in synch during real-time operation.
    The second method 'Timestamp Mode' simply labels each sample from the AD9094 with the SYSREF signal. This doesn't affect any internal operation of the AD9094, but encodes the SYSREF signal into the datastream. This can be used for offline post-processing.
    Since I do not need real-time synchronization, I have been focusing on the 'Timestamp Mode'. I only want to read out the SYSREF value for each sample after a recording, I do not want to edit the value or alter the behavior of the AD9094 during operation.
    Perhaps I have misunderstood the 'Multichip Synchronization' section. If the SYSREF value is inaccessible outside of the individual AD9094 chip, while the AD9094 is set to Timestamp Mode, how can this synchronization mode be used to align the timing multiple chips?
    Is there a preferred method for aligning data streams from multiple AD9094-1000EBZ development boards, each with their own ADS7-V2 FPGA?
    - Luke
