HI, Sir
i have a project that convert the analog sensing signal to digital using LTC2203
my circuit and configuration of ADC is as follows,
After capture the digital out and compare with analog signal, the result shows that i need to set the latency of capture enable signal "ADC_CLK_IN" to 3, and data should be correct.
However the datasheet shows latency of LTC2203 is 7.
But in fact, i really capture the correct data when i set 3 clock delay from signal "ADC_CLK_IN".
So, my question is "Is any possible configuration or layout or something error that makes the latency of LTC2203 change to 3 "
Best Regrades
ctchan
