AD8040
Production
The AD8040 is a quad, rail-to-rail input and output high speed amplifier with a quiescent current of only 1.3 mA per amplifier. Despite its low power consumption...
Datasheet
AD8040 on Analog.com
I want AD80404BBPZ-3000 pdf, ths~ e-mail : yangkaijie@jowin-tech.com
PaulCA - Moved from Operational Amplifiers to High-Speed ADCs. Post date updated from Thursday, August 29, 2024 4:16 AM UTC to Friday, August 30, 2024 1:31 AM UTC to reflect the move.
Hello JOWIN,
I have moved this query to the High-Speed ADCs Community. Someone here should be able to assist you better.
Paul
Hello JOWIN ,
This part is not supported by Analog Devices and is Obsolete for some time. Might I enquire where you received information regarding this product?
What is the nature of your application and maybe we can support with an alternative?
Oisín.
This part number (i.e. (AD80xxx) is considered a "special" part number assigned to a generic ADI high-speed ADC in which a customer may ask for specialized testing, ext beyond what is done for the generic ADI part. The datasheet for these "special" parts are reserved for the OEM customer who specifically ordered this part since these customers typically have to pay more for their special request.
Best guess is that the generic part is the AD9208. That is the best we can offer.
Regards.
AD9208 Datasheet and Product Info | Analog Devices
I no longer work for ADI. It sounds like you have a JESD204B configuration issue (since you confirmed JESD204 B test mode is working) where one is not allowing for proper mapping of ADC virtual converters to the JESD204B transport layer. Suggest reading that section of datasheet again to ensure that you are selecting the correct settings based on your ADC digital path configuration. Also suggest using the transport layer mapping test mode where patterns are inserted for each virtual converter, M, to make it easier to debug.
Someone from factory will need to support you if you continue to have issues.
thanks
thanks
Hello my friend:
Have you successfully applied this chip?Can it be used as AD9208?
I am also looking for the application information of this chip.
Thank you.
