AD9276 diff input
Product Number: AD9276
I have a question about AD9276. Does AD9276 support real differential input? i.e., negative input is a 180 degree phase shift reference with positive input? If that's ok, what do we do with feedback pin (LO-x, LOSW-x). Can we just leave them float? Thanks.
Che
Parents
    The AD9276 does not support differential input because the LNA is designed to be driven from a single-ended signal source. You may use a differential-to-single-ended signal converter to connect with it. The part will still function when the LO-x, LOSW-x pins are left floating. These pins are used to set the input impedance of the part. Please see the Active Impedance Matching section of the datasheet for more info.
Reply
Children
No Data
