Hello support team,
We are planning to use AD9643 with xilinx virtex VU440 FPGA. Is it possible from your end to provide reference HDL design for AD9643 that we can port it to another carrier ( VU440_ Xilinx FPGA). Awaited your response.
AD9643
Recommended for New Designs
The AD9643 is a dual, 14-bit analog-to-digital converter (ADC) with sampling speeds of up to 250 MSPS. The AD9643 is designed to support communications...
Datasheet
AD9643 on Analog.com
Hello support team,
JAlipio - Moved from High-Speed ADCs to FPGA Reference Designs. Post date updated from Tuesday, May 28, 2024 9:23 AM UTC to Wednesday, May 29, 2024 2:48 AM UTC to reflect the move.
iulia - Moved from FPGA Reference Designs to High-Speed ADCs. Post date updated from Wednesday, May 29, 2024 2:48 AM UTC to Wednesday, May 29, 2024 10:30 AM UTC to reflect the move.
Hi Maitry
I have sent your request. Kindly check your email and verify if you have received the source code.
Thank you.
Hi Maitry
Thank you.
Hello sir,
Thank you for your quick support.
Yes, I have received the same.
