Where can I download the testing code of AD9273? I need to read/write the configuration registers by SPI.The code should written in Verilog. Can the ADI technical support team send me some source code please?
Thanks!
AD9273
Production
The AD9273 is designed for low cost, low power, small size, and ease of use. It contains eight channels of a low noise preamplifier (LNA) with a variable...
Datasheet
AD9273 on Analog.com
Thanks!
Hi YHZ123
Thanks for your interest in AD9273.
To proceed with the FPGA source code request, the team will be asking some personal information for verification.
Kindly accept my friendship request.
Hello JAlipio,
Thank you for your reply. I have accepted your friendship request.
Hi, I have already sent your request. Kindly check your email and verify if you have received the source code.
Thank you.
Thank you, I have received it, will try it out!
I have received the code and am currently learning this code.
May I ask if the code you sent me is specifically for AD9273, or is it written for another similar ADC? The reason I am asking is because the AD9273 is a 12-bit ADC, but the code (capture.v) seems to be written for a 14-bit ADC instead.
Thank you.
