AD9081
Recommended for New Designs
The AD9081 mixed signal front end (MxFE®) is a highly integrated device with four 16-bit, 12 GSPS maximum sample rate, RF digital-to-analog converter...
Datasheet
AD9081 on Analog.com
I am using AD9081 EVM running with Xilinx KCU105(Kintex ultrascale FPGA). Design is migrated from analog device provided HDL and no-os driver for VCU118. After loading the elf file, I am getting the QPLL TX buffer underflow error, status: 0x61 on serial port.
Log file for the serial port is attached.
Kindly suggest the changes to come out this issue.
Hello
rx_adxcvr: OK (10000000 kHz)
tx_adxcvr: OK (10000000 kHz)
ERR: ../noos/drivers/axi_core/jesd204/axi_adxcvr.c:527:adxcvr_clk_enable(): adxcvr_clk_enable: QPLL TX buffer underflow error, status: 0x61
ERR: ../noos/drivers/axi_core/jesd204/axi_adxcvr.c:534:adxcvr_clk_enable(): adxcvr_clk_enable: QPLL TX buffer overflow error, status: 0x61
ad9081_jesd_rx_link_status_print: JESD TX (JRX) Link1 0x0 lanes in DATA
ad9081_jesd_tx_link_status_print: JESD RX (JTX) Link1 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid
DAC IRQ status 0xf043000000
IRQ_STATUS0: 0x0
ad9081_multichip_sync:2
ad9081_multichip_sync:3
AD9081 Rev. 3 Grade 10 (API 1.2.2) probed
tx_jesd status:
Link is enabled
Measured Link Clock: 249.998 MHz
Reported Link Clock: 250.000 MHz
Lane rate: 10000.000 MHz
Lane rate / 40: 250.000 MHz
LMFC rate: 7.812 MHz
SYNC~: asserted
Link status: CGS
SYSREF captured: Yes
SYSREF alignment error: No
rx_jesd status:
Link is enabled
Link status: CGS
tx_dac: Successfully initialized (249996948 Hz)
rx_adc: Successfully initialized (249996948 Hz)
Running TinyIIOD server...
If successful, you may connect an IIO client application by:
1. Disconnecting the serial terminal you use to view this message.
2. Connecting the IIO client application using the serial backend configured as shown:
Baudrate: 115200
Data size: 8 bits
Parity: none
Stop bits: 1
Flow control: none
deljones - Moved from High-Speed ADCs to FPGA Reference Designs. Post date updated from Wednesday, February 21, 2024 4:43 AM UTC to Thursday, February 22, 2024 2:29 PM UTC to reflect the move.
nirbhay100 - Moved from FPGA Reference Designs to High-Speed ADCs. Post date updated from Thursday, February 22, 2024 2:29 PM UTC to Saturday, February 24, 2024 5:17 AM UTC to reflect the move.
Moved to FPGA Reference Design community for their reply.
Have you checked out this thread? RE: AD9082-FMCA-EBZ, QPLL RX buffer underflow error With focus on the comment I linked, but not only.
Iulia
I have checked the thread as mentioned in the link.
Now I changed the QPLL0 used for the Tx link to CPLL as in the app_JESD.c file
#ifdef TX_XCVR_BASEADDR
struct adxcvr_init tx_adxcvr_init = {
.name = "tx_adxcvr",
.base = TX_XCVR_BASEADDR,
/*.sys_clk_sel = ADXCVR_SYS_CLK_QPLL0,*/
.sys_clk_sel = ADXCVR_SYS_CLK_CPLL,
.out_clk_sel = ADXCVR_REFCLK_DIV2,
.lpm_enable = 0,
.lane_rate_khz = tx_lane_clk_khz,
.ref_rate_khz = reference_clk_khz,
#endif
#ifdef RX_XCVR_BASEADDR
struct adxcvr_init rx_adxcvr_init = {
.name = "rx_adxcvr",
.base = RX_XCVR_BASEADDR,
/*.sys_clk_sel = ADXCVR_SYS_CLK_CPLL,*/
/*.lpm_enable = 1,
.lane_rate_khz = rx_lane_clk_khz,
.ref_rate_khz = reference_clk_khz,*/
.lpm_enable = 1,
#endif
TX status is now in data and DACs are working. However, the Rx link status is still in the CGS stage.
The serial terminal log is below:
Hello
ad9081_jesd_rx_link_status_print: JESD TX (JRX) Link1 0xF lanes in DATA
DAC IRQ status 0xf043000040
tx_jesd status:
Link is enabled
Measured Link Clock: 249.997 MHz
SYNC~: deasserted
Link status: DATA
rx_jesd status:
Link is enabled
Link status: CGS
tx_dac: Successfully initialized (249998474 Hz)
rx_adc: Successfully initialized (249998474 Hz)
Baudrate: 115200
Data size: 8 bits
Parity: none
Stop bits: 1
Flow control: none
Kindly suggest what can be done.
Hi Nirbhay100,
Apologies for missing your reply, but I see you moved your thread to the High-Speed ADCs community and I didn't get notifications about this, strangely. Maybe because I'm not part of this one.
Did you solve your issue in the meantime?
Iulia
