Programming AD9213 Eval Board EEPROM
Product Number: AD9213
I'm designing a board with an AD9213 on it that will connect to the ADS8-V1EBZ board.  I'd like to use the same image that the the Eval Boards use to test it out.  The AD9213 has an EEPROM located at U27 that I'm assuming is the Board ID EEPROM.  I've read that this EEPROM typically contains some information about the AD9213 eval board so that the image will work.  What information is given in this particular EEPROM?  And  can you point me towards information on reprogramming it?  (I've seen this on other ADI eval boards but not this one).
Thank you,
Top Replies
