I would like to get the .cfg and .cal files for the AD9699 to use with the SPIController software, but the ftp site doesn't seem to work. where can i get it?
AD9699
Recommended for New Designs
The AD9699 is a single, 14-bit, 3 GSPS analog-to-digital converter (ADC). The device has an on-chip buffer and a sample-and-hold circuit designed for low...
Datasheet
AD9699 on Analog.com
AD9208
The AD9208 is a dual, 14-bit, 3 GSPS analog-to-digital converter (ADC). The device has an on-chip buffer and a sample-and-
Datasheet
AD9208 on Analog.com
AD9689
The AD9689 is a dual, 14-bit, 2.0 GSPS/2.6 GSPS analog-to-digital converter (ADC). The device has an on-chip buffer and a sample-and-hold circuit designed...
Datasheet
AD9689 on Analog.com
Hi nagashimatamotsu ,
Thank you for your interest in AD9699.
Could try using ACE for evaluating AD9699? Please check this wiki guide: EVALUATING THE AD9208 / AD9689 / AD9699 ANALOG-TO-DIGITAL CONVERTER [Analog Devices Wiki]
Peevee
Hi PeeveeS
Thank you for the information
We will try to see if evaluation with ACE is possible in our environment.
Let me know if you have questions.
For the FTP link you mentioned, can you try accessing the link in Internet Explorer?
FTP links usually work only when using Internet Explorer
I tried to access the following address with microsoft edge, but I could not access it.
(I tried Internet explorer mode also)
ftp://ftp.analog.com/pub/adispi/A2DComponents/Install/SPIController_Setup.exe
Many thanks
Thank you for sharing. This link is for the installer of SPI Controller.
I checked the files I have related to the SPI Controller, there is no available *.cfg and *.cal files for the AD9699.
Please proceed with using ACE.
Peevee
Thank you for checking
Understood, I will proceed with the evaluation using ACE.
Many thanks
