I have purchased the AD9213 development kit, the AD9213-10GEBZ-B and the ADS8-V1EBZ. Is it possible to share the FPGA reference code for this design. Thanks in advance.
AD9213
Recommended for New Designs
The AD9213 is a single, 12-bit, 6 GSPS/10.25 GSPS, radio frequency (RF) analog-to-digital converter (ADC) with a 6.5 GHz input bandwidth. The AD9213 supports...
Datasheet
AD9213 on Analog.com
AD9681
The AD9681 is an octal, 14-bit, 125 MSPS analog-to-digital converter (ADC) with an on-chip sample-and-hold circuit that is designed for low cost, low power...
Datasheet
AD9681 on Analog.com
Hi TonyC1,
Thank you for your interest in AD9213. My colleague will send you the FPGA reference code.
We'll update you once the code is sent to you.
Peevee
Got it thank you
I received the FPGA package, but it seems 1 directory is missing, "embedded_src/microblaze_crt/"
This directory should have the following files to build the elf:
ASSEM_SRCS += embedded_src/microblaze_crt/crt0.S
ASSEM_SRCS += embedded_src/microblaze_crt/crtinit.S
ASSEM_SRCS += embedded_src/microblaze_crt/_exception_handler.S
ASSEM_SRCS += embedded_src/microblaze_crt/_program_clean.S
ASSEM_SRCS += embedded_src/microblaze_crt/_program_init.S
OBJ_SRCS += embedded_src/microblaze_crt/crti.o
OBJ_SRCS += embedded_src/microblaze_crt/crtbegin.o
OBJ_SRCS += embedded_src/microblaze_crt/crtend.o
OBJ_SRCS += embedded_src/microblaze_crt/crtn.o
After studying the code, it looks like you sent me the code for the AD9213-10GEBZ (the A model) not the B model AD9213-10GEBZ-B can you please send me the code for the AD9213-10GEBZ-B!
Thanks
Hi TonyC1,
I'll check on that.
FYI ADI is on summer break this week, so I won't be able to get information until sometime next week.
Doug
Hi TonyC1,
Sample FPGA code for AD9213-10GEBZ-B and ADS8-V1EBZ has been sent to you.
Doug
I am working with HSC-ADC-EVALEZ +AD9681. Now my work is to program the FPGA on HSC-ADC-EVALEZ (Virtex 6). Whether is there any source code for this board? both VHDL and verilog is better.
Thank you so much!
Hi JSA,
Thank you for your interest in AD9681. The FPGA on HSC-ADC-EVALEZ gets programmed by VisualAnalog software. You do not need to program the FPGA outside of VisualAnalog. Are you having problems programming the FPGA?
I'll still request the sample FPGA code be sent to you.
Doug
Hi DougI,
Thank you for your help.
I have some questions about FPGA programming. I'll read this code carefully.
