HMCAD1511-EBZ and SDP-H1 Questions
Product Number: HMCAD1511
I have recently received these two parts and I have them up and running with the ACE software, but I have some questions.
1. What is the functionality of the external trigger input, I can see that it is fed into the FPGA, and that I can enable it in the FPGA register map, but there is no explanation as to what the actual result is.
2. Is there any sample FPGA code available, so that I can better understand its functionality.
3. Is there any way of accessing the data stream from the SDP-H1 via an API, it seems to use python so it would be logical to make this available.
Thank you for your help.
Moved & added product number tag
[edited by: emassa at 1:32 PM (GMT -4) on 8 Jun 2023]
Top Replies
    •  Super User
    Jun 15, 2023 +2 verified
    Hi tmm101,
    1. What is the functionality of the external trigger input, I can see that it is fed into the FPGA, and that I can enable it in the FPGA register map, but there is no explanation…
  • Hi tmm101,
    Thanks for your interest in HMCAD1511.
    I will send the code right away. Please check your email and verify once received.
    Xavier
  • Hi tmm101,
    Using the external trigger input, the user has precise control on the data capture timing by sending a pulse to the EXT_TRIG input, unlike when using ACE Run button which has delays from PC to SDP-H1.
    It is possible, but right now, we are resource-constrained, and requesting for an API will take a long time. Thus, we can't guarantee.
    Thank you.
    Xavier
