Hi
I am DFAE in Japan.
Our customer will use AD9083.
AD9083 datasheet does not define setup and hold timing specification of SYREF and SYNCIN.
Do SYREF and SYNCIN automaticaly align device clock?
Best regards
N.Kokubo
AD9083
Recommended for New Designs
The AD9083 is a 16-channel, 125 MHz bandwidth, continuous time S-? (CTSD) ADC. The device features an on-chip, programmable, single-pole antialiasing filter...
Datasheet
AD9083 on Analog.com
Hi
I am DFAE in Japan.
Best regards
N.Kokubo
Hi ,
Please see attached additioal details on SYSREF for the AD9083 in an Engineering note as an interim solution while I revise the datasheet. I dont have set up and hold times for SYSREF wrt sampling clock, I expect to be able to include them in the next datasheet revision. The minimum pulse width for sysref would be same as clock period of device clock (the sampling clock). regards Brigid.
Hi Brigid san
Thank you for answer about SYSREF.
I understand SYSREF automaticall aligned device clock.
Will SYNCINB be automaticall aligned device clock,too or is synchronization unnecessary?
Best regards
N.Kokubo
