LTC2249 Input range
The user asked if the LTC2249 ADC's full scale range is 7dBm for ±1V mode with 100-ohm input impedance, and if the minimum input power level is -66dBm due to a 73dB SNR. The support engineer confirmed the full scale range is 6.99dBm but clarified that the SNR is in dBFS, not dBm, and the analog signal is -1dBFS as per test conditions.
Product Number: LTC2249
Hi
According to LTC2249 datasheet for the ±1v mode (V sense connect to Vdd), is the ADC's full scale range 7dBm for a 100-ohm input impedance ?
Due to a 73dB SNR is the minimum input power level of ADC -66dBm?
Best regard
  • Hi jessi,
    Thanks for your interest in LTC2249.
    Yes, this is correct. The ADC full-scale swing is 2Vpp and is equivalent to 6.9897dBm for 100-ohm input impedance.
    No. The SNR parameter is in dBFS scale, and not should be interpreted in dBm. SNR (dBFS) = Signal (dBFS) - Noise (dBFS)
    As for the 73dBFS SNR, the analog signal is -1dBFS as per test conditions.
    Xavier
