I would like to use LTM9011 for data acquisition purpose ,
Product Number: ltm9011-14 with ltc6600-20
 the input signal is 0-10V with  BW  of 20MHz . I have chosen the  LTC6600 LNA with 20Mhz LP filter. As per the data sheet we need to use figure 7 Frnt End Circuit Using a High Speed Differential Amplifier, if want to use the differential amplifier as input stage for gain and filter. could you plz suggest some thing else if this not correct
on Jun 8, 2023 4:37 AM
Hi Nias,
Apologies for the delayed response. Our LTC experts might be busy at this time but though I am not an expert of this product, please allow to comment on some observations.
The LT6600-20 might be a good ADC driver for but keep in mind that LTM9011-14 allows an analog input range of only 1 to 2 Vp-p. You might need to seek guidance from Differential Amplifiers community the correct configuration to attenuate your input signal (0-10V) to match specified ADC input range.
Meriam
