About the /OE terminal function and timing diagram of LTC2202/LTC2203
Category: Datasheet/Specs
Product Number: LTC2203
Hello everyone
I am planning to use LTC2202/LTC2203 to get a fixed number of samples periodically.
Since there is an output enable pin /OE, and the datasheet states that /OE high level puts "digital outputs" in Hi-Z state, I think maybe I can pull up its level after counting a certain number of CLKOUT+ rising edges.
I'm not sure if the /OE high level disables both CLKOUT+ and D0~D15(sample output terminals)   or only the D0~D15?
And the datasheet has no timing diagram about /OE terminal, but I think there may be an output delay(or set up time) for sample output terminals to be valid after the /OE falling edge.
Is there any other user guide or design reference in which I can find the output delay time ?
I would appreciate it if you could reply.
Alaudi
