SPI reading issues in AD9653 ADC configuration register.
Product Number: AD9653
We are using the ADC (AD9653) which supports 3 wire SPI communication, and we are using SPI level shifter (NC7WZ07P6X) which will convert the 4 wire SPI communication from FPGA to 3 wire SPI communication for ADC.
I am trying to read the Chip ID register 0x01 in ADC (AD9653) using SPI controller. So, I need to first transfer 0x8001 as an instruction header for read command to the ADC and then should be receiving 8-bit chip ID as 0xB5. When I run the application, I can see chip select going low and then SCLK clock(500KHz) getting generated and 0x8001 in MOSI line for first 16 clock cycles of SCLK. But instead of getting 0xB5 I am receiving 0x00 in MISO line. This is same for all the registers.
Please find the attached snapshot for the schematic and SPI read transaction in ILA.
With regards,
Monica
  • Hi MoniDeena,
    Thanks for your interest in AD9653.
    I recommend the following steps:
    • Monitor the MISO, MOSI, and SDIO lines using oscilloscope to check expected behavior.
    • Try to replace the pull-up resistor R10 to lower values like R7 value; the open-drain buffer might be having difficulty pulling down the line due to high pull-up resistor value.
    Thank you.
    Xavier
  • Hi Xavier,
    Thanks for your reply.
    • We have monitored MISO, MOSI and SDIO lines using oscilloscope. The data we have generated in MOSI getting to SDIO properly, but we aren't getting any response in the SDIO line from ADC.
    • We have configured the internal reference voltage in ADC and we are getting the exact ref voltage (1V) internal and Vpp = 2V as mentioned in the datasheet.
    • Is there any recommended Register Programming Sequence for SPI configuration?
    • We didn't generate the sample clock to ADC. So, is there any chance that ADC is not READBACK because of the source clock?
    Thanks & Regards,
    MoniDeena
  • Hi MoniDeena,
    Have you tried to replace the 27kohm resistor of R10 to lower values like that of R7 and monitor the line?
    Xavier
  • Hi Xavier,
    I have replaced the 27kohm into 1kohm resistor in R10 and i have monitored MISO, MOSI and SDIO using oscilloscope. In MOSI line we are getting the exact data which we are given and it's also flowing in SDIO line. But we are not able to READBACK the data in SDIO line from the ADC. So, there will be no data in MISO line.
    Thanks & Regards,
    MoniDeena
  • Hi MoniDeena,
    Could you confirm the following:
    1. In MOSI, there is no pull-up in the input side of the buffer. Could you confirm if the pull-up is on the FPGA/controller side?
    2. During Idle state of the MOSI line, is it low? If it is idle low, could you try changing to idle high? This is to keep the open-drain buffer connected to MOSI in high-Z state when you are doing read transaction with MISO line.
    Thank you and regards,
    Xavier
