ad9689 sample rate in 2.7GHz can't work
Category: Datasheet/Specs
Product Number: AD9689-2600
AD9689-2600 data sheet promise max 2.7G sample rate,I use in 2.6G full bandwidth mode work well,but in 2.7G the PLL can't lock.Anyone can help with this problem? Thanks!
Updated to new ask a question form
[edited by: GenevaCooper at 12:25 PM (GMT -4) on 5 Jul 2022]
Parents
  • the AD9689-2600 will work at 2.7GHz sample rate. Please check the settings and try again. See figure 59 of the datasheet for more information
  • Thank you for your reply.My regster settings are below.
    {0x0000,  0x81, 1, SPI_REG_WRITE},
    {0x0200,  0x00, 1, SPI_REG_WRITE},
    {0x0201,  0x00, 1, SPI_REG_WRITE},
    {0x0571,  0x15, 1, SPI_REG_WRITE},  //jesd powerdown
    {0x0120,  0x04, 1, SPI_REG_WRITE},  //sysref contiuous ring or 0x0A fall
    {0x058B,  0x87, 1, SPI_REG_WRITE},  //scrambling en
    {0x058E, 0x01, 1, SPI_REG_WRITE},  //M=2
    {0x058C,  0x00, 1, SPI_REG_WRITE},  //F=1
    {0x058D, 0x1F, 1, SPI_REG_WRITE},  //K=20
    {0x056E,  0x00, 1, SPI_REG_WRITE},  //》=6.75G-13.5G
    {0x0571,  0x14, 1, SPI_REG_WRITE},  //jesd poweren
    {0x0701,  0x86, 1, SPI_REG_WRITE},
    {0x073B,  0x37, 1, SPI_REG_WRITE},
    //{0x056F,  0x00, 1, SPI_REG_READ},  //read pll status
    {0x1228,  0x4F, 1, SPI_REG_WRITE},
    {0x1228, 0x0F, 1, SPI_REG_WRITE},
    {0x1222,  0x00, 1, SPI_REG_WRITE},
    {0x1222,  0x04, 1, SPI_REG_WRITE},
    {0x1262,  0x08, 1, SPI_REG_WRITE},
    {0x1262,  0x00, 1, SPI_REG_WRITE},
    And zhe AD9689-2600 CLK is 2.7GHz.The SYSREF is 3.375MHz.And FPGA JESE204B PHY core set the lane rate is 13.5Gbps.Refclk and core_clk is 337.5MHz.I don't know what else I need to set?And can you tell me the reasons why PLL can't be locked ?I did not  find a detailed description of PLL related structures.
  • How are you providing the 2.7GHz clock signal? Are you sure you have enough clock amplitude at the CLK+/- pins of the AD9689?
  • I use  LMX2820 as  the  clk source.The RFOUT amplitude is theoretically about 1.3vpp.I don't have tools to actually measure it .But 2.6GHz work well.I don't think its amplitude is too small
  • How are you connecting the clock signal into the AD9689 eval board? single ended? differential? this most certainly is a clock amplitude issue where the chip isnt getting enough clock amplitude at its CLK+/- pins to generate a stable clock signal
  • Differential.Thank you for your reply.I will try to measure the quality of the clk.
Reply Children
No Data
