LTC2155-14
Production
The LTC2157-14/LTC2156-14/LTC2155-14 are 2-channel simultaneous sampling 250Msps/210Msps/170Msps 14-bit A/D converters designed for digitizing high frequency...
Datasheet
LTC2155-14 on Analog.com
Do you have a pull up on SDO? The SDO pin is open drain, and requires a 2k pull up on SDO, else it will just be zeros,,
Clarence.Mayott,
Thanks a lot for the help. That is exactly the reason. After I add 2K pull up, I got the correct SDO output.
Cheers,
ytian
Great! Let me know if you have any other questions.
