I'm using the HSC-ADC -EVAL CZ with AD9230.
I want to be able to save data in response to a trigger and wait without taking data until the next trigger is entered.
Is there a way to output one data for each trigger rise with visual analog?
This document outlines how to use the trigger feature with the AD9230:
QuickStartGuide_AD9230_External_Trigger
Let me know if you have any questions.
David
I was able to try the procedure to enable external triggering.
However, VisualAnalog has generated a CSV file regardless of the trigger. Also, -1 is recorded in the CSV file before the trigger is entered. Is there a way to improve these?
tatu
We suspect that you do not have the right .bin file for step 9 in the document above as it is not distributed with the normal Visual Analog install. Please extract it from the attached file and place it in the default location: C:\Program Files (x86)\Analog Devices\VisualAnalog\Hardware\HSC_ADC_EVALC
David
I put the file in the specified location and tried the procedure, but the behavior did not change.
Is there a way to improve it?
Tatu
By the way, I had a bin file when I asked the question last time, so I'm trying all the steps.
