AD9258 is not getting configure?
Dear Team,
I hope you are doing well.....!!
I am trying to configure AD9258 ADC using SPI, I checked the signals at resisters near to SCLK, SDIO and CSB, there i Am able get signals but while checking Vref Voltage it is showing its default value of 2Vpp, I can't able to identify weather the ADC gets configure or Not, Kidnly suggest the possible ways to check the configuration.
Following are my Register values:
32'h00001800
32'h00050300
32'h00FF1000
32'h00088000
32'h00090100
32'h000B0000
32'h000D0000
32'h000E4000
32'h000F0000
32'h00100000
32'h00140000
32'h00160000
32'h00170000
32'h00181000=Vref
32'h00300000
32'h01000700
Kindly Share your response.
    As per understanding, you are trying to read the default configurations of the Memory Map registers? Am I correct? I spotted some mismatch in address register 0x0E and 0x18 (Vref select) You can verify the default values in Table 17 of the AD9258 data sheet.
    For Voltage Reference configuration, please check page 29 of the datasheet.
    Meriam
