Hello support team,
I am working with AD9681 + HSC-ADC-EVALEZ. I've already have the HDL code for configure it.
But in the code I have, there is only option for two lane mode.
Could I ask the HDL code part for one lane mode?
Thank you,
HOANG
AD9681
Recommended for New Designs
The AD9681 is an octal, 14-bit, 125 MSPS analog-to-digital converter (ADC) with an on-chip sample-and-hold circuit that is designed for low cost, low power...
Datasheet
AD9681 on Analog.com
Hello support team,
Thank you,
HOANG
Hi HOANG,
Thank you for your interest in AD9681.
The FPGA program for AD9681 is hard-coded for 2-lane mode. The AD9249 is the 16 channel 1-lane version of the AD9681.
I'll request that the sample FPGA code for AD9249 and HSC-ADC-EVALEZ be sent to you.
Doug
Hi Dougl,
Thank you.
Could you check the PIN to me? It seem something wrong about DCO1 and DCO2. Thank you
HOANG
Hi HOANG,
Would you please explain your question/concern a bit more? Are you saying that the FPGA code shows DCO1 is connected to H11 and H10 instead of DCO2?
This is what I see in the code:
AD9681 code
NET lvds_dco2_p LOC = H11 | IOSTANDARD = LVDS_25 | DIFF_TERM = TRUE ; # LA00
NET lvds_dco2_n LOC = H10 | IOSTANDARD = LVDS_25 | DIFF_TERM = TRUE ;
AD9249 code
Maybe I am misunderstanding your question.
Doug
Thanks Dougl, I think I know the problem. It seem I see the two code version of AD9681. I just check the last one.
I have another question. "I want to put some process after "capturing the data" and transfer the result to pc. could I do it with 8 parallel channel at the same time?
