Bad SMA connector assembly of AD9082-FMCA-EBZ
In the AD9082-FMCA-EBZ picture posted on the website, the connector assembly does not look good.
Soldering is inconsistent and looks excessive.
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/eval-ad9082.html#eb-overview
Please see the mounting Instructions for the SMA connector.
https://belfuse.com/resources/ApplicationNotes/CinchConnectivitySolutions/Johnson/app-note-CCS-JOHN-SMA-HF-end-launch-connectors-application-note.pdf
Did you have any problems testing with high-frequency signals?
Actually I'm having a similar problem with connector assembly.
My board is even assembled with the connector tilted.
This mismatch causes S21 to fructurate and attenuate the signal significantly at high frequencies in my board.
In my opinion, ADI needs to check the AD9082-FMCA-EBZ manufacturing process.
I'm thinking about exchanging it, but I'm worried that the new product will be the same.
Best Regards,
Hyeunpil
Word correction
[edited by: HP.Jin at 1:57 AM (GMT -4) on 20 Apr 2021]
Top Replies
    Apr 20, 2021 +2 verified
    HP.Jin, thank you for bringing this to our attention. We will work with our manufacturer to ensure proper soldering recommendations are followed.
Parents Reply Children
No Data
