Frequency Planning with AD9467 ADC
I like this ADC because of the high sample rate and good dynamic performance.  I'm really only processing 20MHz of bandwidth.  I am thinking that I should be able to pick a sample rate and analog input frequency range to position the largest harmonics out-of-band.  I have flexibility on input freq. range, clock rate - my main goal is to do a very robust design with lowest noise/distortion in my 20MHz band.  I am also trying to avoid a complex = expensive or hard to manufacture filter before the ADC.
Anyone have suggestions?  Tools I should use?  Other?  Thanks...  Scott
Parents
    on Feb 5, 2011 12:16 AM
    Hi scottbehr,
    Choosing a high sample rate converter will definitely aide in reducing the cost and complexity of the anti-aliasing filter (AAF). Next, if possible, choose a 20MHz BW to be within baseband at Fs/4 or greater, this will push the harmonics in to the next Nyquist zone where the AAF will continue to roll-off. Generally at lowpass filter will only be required if this done, keeping the cost down and the complexity and component count low. If a higher 20MHz BW is chosen, >bandbase, then a bandpass filter will be required which will have an increased effect on complexity and component count.
    I also attached an application note that discusses some of these AAF tradefoffs.
    Rob
    AN-827_0.pdf
Reply
    Hi scottbehr,
    Rob
    AN-827_0.pdf
Children
No Data
