I would like to get an IBIS model file for an AD5058. if none are available is there any model info you can provide?
AD9058
Obsolete
The AD9058 combines two independent high performance
8-bit analog-to-digital converters (ADCs) on a single monolithic
IC. Combined with an optional onboard...
Datasheet
AD9058 on Analog.com
Hi CarlM-
I checked into this, and unfortunately because this is an older part we weren't regularly generating IBIS models when it was released. As a result, we don't have any IBIS related models or Design Sim data for this product. The most applicable information regarding the output drivers is listed in the Timing section of the datasheet on pg 7. I hope this helps.
AndyR
