Minimum Frequency of Inputs for AD9214 and AD6644
  Good morning.  I have a customer inquiring as to how low the freqeuncy of a signal can be to drive the analog inputs of the AD9214-105 and the AD6644-65.  He needs to be able to accommodate some signals that will be in the range from 50KHz - 100KHz.
  Can either or both of these parts handle a signal frequency this low if using the AD8138 in a DC coupled circuit?
  Also, what is the life expectancy of each of these parts?  In other words, does ADI have an expected PDN date for each of these parts?  Thank you.
  Richard A. Pensabene
Parents
  • Hi David,
    I started the design (and layout) with the AD9214 but I am questioning my wisdom due to the end of the device.
    The AD9215 is also not a new comer, but its a little newer and the Eval boards are available (I was told the AD9214 Eval boards were not available from Avnet inside sales).
    For the DC-coupling of AD9214, I simply went with the suggestion in Fig 9 p13, (actually closer to the Figure 47 p22 in AD8138 data sheet).
    Question: With the AD8138 and AD9214/AD9215, can I get nice sampling of Log Video pulses, maybe 1 msec wide?  This is essentially all positive DC sampling.  We want 8+ bits of dynamic range.  Any EOL issues with the devices?
    Jon
Reply
  • Hi David,
    Jon
Children
No Data
