Query about AD6643's NSR
Hello, supporter
I use AD6643 as IF sampling ADC. Attached is the results when NSR enabled and disabled.
Not sure whether the results are correct...
The sampling rate is 125MSPS, while the analog input is 156.25MHz/+-12.5MHz.
Could you please help give some comments on the results?
Thanks in advance!
BR,
Wayne
attachments.zip
    on Oct 18, 2013 11:55 PM
    Hi Wayne,
    There will be a difference in the number of bits transitioning at lower input signal levels with and without NSR enabled.  Can you provide some more details on your test conditions (ie input amplitude, clock amplitude and what input sources you have)?  Also, can you provide an FFT of your results?  I am not sure I fully understand your issue here.  Can you help me to understand what your concern is?
    Thanks and regards,
    Jonathan
    on Aug 2, 2018 2:29 PM
    Thank you,
    EZ Admin
