AD9675 data sheet typo? (ILAS repeat count)
In the AD9675 data sheet Rev. A, Table 31 (Memory Map Registers), p. 54, register JTX_LINK_CTRL4 (0x145) has one field that sets the ILAS repeat count:
Initial lane alignment sequence repeat count
0000 0000 = 4 × K + 1 (default)
0000 0001 = 4 × K + 2
1111 1111 = 4 × K + 128
Since this field is 8 bits, it should have 256 possible settings. So I reckon the last line should read either:
1111 1111 = 4 × K + 256
or, if the intent was to allow only 128 valid settings:
0111 1111 = 4 × K + 128
1000 0000 = reserved
1111 1111 = reserved
Please verify which is correct.
AD9675.pdf
  • Hi Tony,
    Yes there is a typo error in this table entry, which will get fixed. But it is not just the max value. The repeat count, say C, goes from 1 to 256 according to the setting in 0x45. The repeat count will repeat the four multiframes of ILAS C number of times, in other words, the number of frames will be C*4*K where K is the number of frames per multiframe.
    Thanks
    Ashraf
