The clock for an AD9635 is from an FPGA PLL in LVDS. In this case, can I directly connect the PLL clock outputs to the clock inputs of AD9635 with capacitors and resistors without using a clock buffer such as AD951x in Fig 60 on page 22 of AD9635 data sheets? If yes, what is the input impedance, i.e. parallel resistors to ground and coupling capacitors? Many thanks.
