EVAL_AD9670
Is it possible to use EVAL_AD9670 with HCS-ADC-EVALEZ throw the AD-DAC-FMC-ADP ?
Parents
    on Feb 3, 2020 3:46 PM 11 months ago
    Hi Mr. Sleptsov,
    Thank you for your interest in AD9670. Just from looking at pictures of the AD-DAC-FMC-ADP, it looks to me like the physical spacing of the Tyco connectors are different from what is on the AD9670 evaluation board. So apart from any possible electrical compatibility issues, it looks like the AD-DAC-FMC-ADP is mechanically incompatible with the AD9670 evaluation board.
    I'm sorry about that.
    Doug
  • Thank for your reply.
    I'll try to find EVAL-ADC-FMC-INT.
    Is it possible to use EVAL_AD9670 with HCS-ADC-EVALEZ throw the EVAL-ADC-FMC-INT ?
    Are AD planning new Eval board for AD9670 (AD9674) with FMC connector?
  • +1
    on Feb 4, 2020 5:18 PM 11 months ago in reply to A.Sleptsov@TWISTDx.co.uk
    Hi Mr. Sleptsov,
    Unfortunately the EVAL-ADC-FMC-INT web page is showing it as being obsolete. I do not know if you can find one.
    Even if you can find one, I doubt that it will work as-is. I have not tried the EVAL-ADC-FMC-INT with the AD9670 evaluation board, but I think it is likely that it would require some hardware "hacks" to make it work electrically, even if it fits mechanically.
    As far as I know, there are no plans to make a new AD9670 board with FMC connector.
    Have you considered the AD9671 evaluation board? This board has an FMC connector and works with the HSC-ADC-EVALEZ.
    Doug
Reply
  • +1
    Hi Mr. Sleptsov,
    Doug
Children
