Strange things with AD9281
I am using the ad9281 as the basis for a USB oscilloscope.
The first problem is noise if I go above 10MHz clocking.
If I reduce the clock speed the noise goes down.
The other problem is with 1 volt in I am getting code 166 out when it should be 128.
Vref is 2 volts.
I am using a PIC micro to clock the a2d then I just read data in to PIC port b so its pretty basic really.
Any advice would be appreciated.
  • I got stuck into the various problems with my system.
    1/ My op amp circuit was too close to the PIC clock circuit and was picking up 8MHz.
    2/ AD9283 required better decoupling.
    3/ The /AIN pin is not biased centrally and I had to put an extra resistor in two bias it centrally.
    4/ The PIC clock seems to interfere with the AD9283 clock and using a different frequency PIC clock resulted in much less noise.
