Hi, to separate analog and digital devices. The masterclock is situated in the digital part of the circuit with a fan-out buffer(a fan-out buffer has multiple clock ouputs to clock multiple clock inputs of different devices). So masterclock and fan-out buffer are in digital part of the circuit, i want to place a rf-transformer that will connect fan-out clock output and the adc LTC2252fa clock input. So the rf-transformer does a single ended to single ended transformation. Are there extra component that i should add? Is this the correct way for doing this? Is the circuit in the picture below sufficient to realize this circuit? The ADC makes part of the analog part of the circuit(as you can see)
