- I want to make a circuit with the AD7147. As the pins are too small, how can I connect it into a breadboard?
Edit Notes
Spelling[edited by: Shafiq at 2:12 AM (GMT 0) on 13 Apr 2019]
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD7147
Production
The AD7147 CapTouchâ„¢ controller is designed for use with capacitance sensors implementing functions such as buttons, scroll bars, and wheels. The sensors...
Datasheet
AD7147 on Analog.com
Our recommendation is to purchase our evalboard
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/eval-ad7147ebz.html#eb-buy
Alternatively an LFCSP breakout board like this may work for you
I had already bought the evaluation board. But from the datasheet , i see that the evaluation board ADC can't be used to test an external sensor . So I bought ADC chip only but I can't understand how can I connect wires to the pin of ADC as the pins are too small . I want to try my sensor with normal wires and resistors first . If everything works, then I will go for PCB .
