I can only read via SPI (ID CODE ,ETC), but the write bit is not accepted, nothing happened when write , I observe the time sequence of spi which meet the requirement of the datashete, what should I do ?
In your follow-up posting are you confirming your SPI Write issue was resolved once you applied the transfer bit via register 0xFF?
