Hi engineer :
I want to use HSC-ADC-EVALCZ to configure my AD9517-4 circuit.The scheme as follows.
The Interface is same as AD9484-500EBZ. Then I loaded AD9517_for_AD9268EVB.cfg and AD9517_for_AD9268EVB.cal file through SPI Controller.The files as follows.
Then I test the waveform use oscilloscope of AD9517-4 signal.
REF input (differential)
chip select
SCLK
SDI
SDO
But I test nothing on the out5 and out3(always zero level).What's wrong about.Thank you very much.
