AD9257 waveform jump
I‘ve had a problem using AD9257. I used it to acquire a sine wave, but the waveform will jump if the input exceed a value, as shown below.
The problem does not occur in all of the 8 channels.
I made a few test boards, and each board has different error channels.
I use AD8138 as the differential Driver. I watched the differential input of AD9257 with an oscilloscope, and it is a standard sine wave.
I used the test pattern function of AD9257 to test my driver program, and I can receive the test pattern correctly.
What is the possible reason for this problem?
Appreciate all your efforts and help.
Thanks
Zhao
  • Hi Zhao,
    Thank you for using the AD9257. You mentioned that the problem does not occur on all channels, and different boards show the problem on different channels. On a given board, are the problem channels the same from power-up to power-up? For example, if only Channel A is not working on one board, will it always be only Channel A that does not work?
    If you are able to post your schematic, I would be glad to look at them.
    Also, as a sanity check, please try a Digital Reset as described in the CLOCK STABILITY CONSIDERATIONS section of the AD9257 datasheet.
    SPI_Write (0x08, 0x03); # Start Digital Reset
    SPI_Write (0x08, 0x00); # Finalize Digital Reset and Return to Normal Operation
    Thank you.
    Doug
  • Hi Doug,
    I really appreciate your reply. It is indeed a problem of CLOCK STABILITY. The power of my clock is little later than AD9257's power. After a digital reset, AD9257 works properly.
    Thank you!
    Zhao
  • Hi Zhao,
    You are very welcome!
    I hope your project goes well.
    Doug
