Using PyUSB and libusbk 3.1.0.0 I was trying to read the register 0x9F. The below are the snippets of the code.
def __init__(self, vid=0x0456, pid=0xB203):
self.dev = usb.core.find(idVendor=vid, idProduct=pid)
def read_reg(self, reg):
try:
# Mention which register to read
self.dev.ctrl_transfer(
0x40, # Host → Device
0xDE,
0x000D,
reg,
None,
timeout=3000
#Reading Data
data = self.dev.ctrl_transfer(
0xC0, # Device → Host
0xDE,
0x000D,
0x00,
1, # Read 1 byte
timeout=3000
return data[0]
Output: Error: Read failed: [Errno None] b'libusb0-dll:err [control_msg] sending control message failed, win error: The semaphore timeout period has expired.\r\n\n'
It seems like the evaluation board is not sending data to the code.
I would appreciate your guidance on the following:
- Is this an issue related to driver configuration? If so, what driver do you suggest?
- If there are any specific initialization steps required before register reads?
Kindly let me know if any more information is needed.
Best Regards,
Shiphi Abraham Thomas
