AD5933 EVAL board firmware CY7C68103
The user is looking for the firmware for the CY7C68103 microcontroller on the AD5933 eval board to program it directly. The support engineer provided a link to the source code and mentioned that the firmware is not available but can be used with the USBFunctions.dll library. The user reported issues accessing the provided FTP link and requested an alternative or direct access to the USBFunctions.dll library code.
I noticed in the VB6 code provided for the eval software refers to the USBFunctions.dll file.
I eventually want to use the AD5933 withe a microcontroller via I2C, but the Eval board comes with the CY7C68103 microcontroller. It would make sense if I just program that directly. Is the eval firmware available at any place for the CY7C68103?
I also tried to download cypress driver but it doesn't work either. I'm assuming that the firmware is developed by AD and that's only compatible with the USBFunctions.dll lib. I want to try to reprogram the cypress controller, but I'm afraid that it will be completely wiped out by my non-working firmware.
