AD9914 Synchronization at 2.5 GHz reference frequency
The user seeks to align a 3.3 V I/O_UPDATE signal with a 1.8 V SYNC_CLK for the AD9914 and synchronize two AD9914s. The final answer suggests using a thread and an application note for guidance on synchronization. The user is also advised to consider lowering the clock frequency to 2.5 GHz to achieve the required synchronization, allowing the 2856 MHz signal to be generated from the alias fo+fref by setting fo to 356 MHz.
I have two questions.
I want to align the I/O_UPDATE signal with SYNC_CLK on an AD9914. I know how to do this and have done it successfully with AD9959 chips. In that case I used two sections of a 74LVC74 D Flip-Flop with 3.3 Vdc power, with the I/O_UPDATE pulse on the D input of the first flip flop and the SYNC_CLK on both clock inputs. I tried doing the same with the AD9914, but the amplitude of the SYNC_CLK signal is too low, about 1.8 V maximum. I think I can make the circuit work if I reduce the Vcc to 1.8 V, but then I will have an output signal that is too low for the 3.3 V logic input of the AD9914.
So the first question is: How do I align a 3.3 V I/O_UPDATE signal with the 1.8 V SYNC_CLK signal and get a 3.3 V logic signal out.
Second question.
I was planning on using an AD9914 to generate a signal at 2856 MHz using a reference clock frequency of 3.5 GHz. This actually works fine, except that I need two signals that are synchronized. I don't care about the absolute timing, but I need the two outputs to have the same phase difference every time I turn the system on. I am now reading that it is not possible to synchronize two AD9914s with a 3.5 GHz clock.
So the second question is: Will I be able to synchronize the AD9914s if I lower the clock frequency to 2.5 GHz? I will be able to get my 2856 MHz signal from the alias fo+fref, by setting fo to 356 MHz.
Jim
