LT3748的工作频率是由什么决定的呢,我查看了芯片手册,里面的参考设计并没有说清楚。另外,LT3748的最大工作频率是多少
The maximum operating frequency in a given application can be approximated from the primary transformer inductance, the windings ratio (NPS), the nominal output voltage and the maximum input voltage. Unless the part is limited by minimum on- or off-times, this maximum frequency will occur when the part is regulating in boundary mode at the minimum peak switch current, and can be derived from: f SW(MAX)≈ VIN(MAX) •(VOUT + VF(DIODE))•NPS LPRI •ILIM(MIN) •((VOUT + VF(DIODE) )•NPS + VIN(MAX)
