你好,
TEC制冷片供电3.3V,1.5A,不能加热,一端要求接地。制冷片集成了NTC,目标温度是0℃。不知ADN8834是否支持这种类型的TEC?
你好,
您好,希望这个能够帮到您ez.analog.com/search
另您也可将问题发布在咱们的全球技术社区哦,会有专门的工程师为您解答的。
https://ez.analog.com/Power/
Hi Michael,
Thank you for reaching out to us. I find this post written in Chinese characters and I just used google translate for me to understand. So please bear with me, and I hope I understand your question correctly.
Regarding to your concern, there are customer in the past who wants the same operation with yours. Either they only need cooling mode or heating mode only. For this type of application, we suggest implementation of diode in series with the TEC module in such a way that it will allow the desired mode, and block the other.
I hope this helps and work with your implementation.
Noel
Hi Noel:
thanks for your support.
yes, you got my question quite correctly.
